I am building an application that is using Ajax (.Net) but I have issues around the client scripting... I have a button linked with an Ajax
call to the server. and it is working just fine. when I return from tne server i want to be able to generate an action on the client side but I do not feel confortable with the API (openLayer / Javascript) could you give me an idea on how to for instance update a specific layer or overlay based on what the server is sending back to the client..
<head id="Head1" runat="server">
    <title></title>
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
    <meta http-equiv="X-UA-Compatible" content="IE=9">
    <link href="~/Styles/MyStyle.css" rel="stylesheet" type="text/css" />
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js" type="text/javascript"></script>
    <script type="text/javascript" language="javascript">
        var OnMapCreating = function (map) {
        var OnMapCreated = function (map) {
       function AjaxCall(arg) {
            var context = Map1;
            WebForm_DoCallback('__Page', arg, AjaxResult, Map1, null, false);
        function AjaxResult(result, context) {
            if (result = "REDRAW_LAYEROVERLAY") {
                var map = Map1.GetOpenLayersMap();
                map.getLayer("layerOverlay").redraw(true);
            else {
                map.addLayer(format.read(new OpenLayers.Format.WKT()));
    </script>
</head>
<body>
        <img src="theme/default/img/loading.gif" alt="loading..." hidden="hidden" />
    <form id="form1" runat="server">
    <asp:ScriptManager ID="ScriptManager1" runat="server">
    </asp:ScriptManager>
        <asp:UpdatePanel ID="CmdArearadius" runat="server" UpdateMode="Conditional">
            <Triggers>
                <asp:AsyncPostBackTrigger ControlID="Button1" />
            <ContentTemplate>
                <fieldset>
                    <legend>CenterScreen</legend>
                    <asp:Button ID="Button1" runat="server" Text="Location" OnClientClick="AjaxCall('LOCATION')"
                        CommandArgument="LOCATION" CommandName="SET" />
                    <legend>Get Active Customers</legend>
                    <asp:Button ID="Button2" runat="server" Text="Customers" OnClientClick="AjaxCall('ACTIVE_CUSTOMERS')"
                        CommandArgument="ACTIVE_CUSTOMERS" CommandName="GET" />
                </fieldset>
            </ContentTemplate>
        </asp:UpdatePanel>
    <cc1:Map ID="Map1" runat="server" OnClick="Map1_Click" Height="800px" Width="800px"
        MapUnit="DecimalDegree" OnClientDoubleClick="getLocation">
    </cc1:Map>
    </form>
</body>
</html>
