AjaxPostbackEvent
Hi ThinkGeo Team
Can you please give me a sample code showing how to wire a client side event that calls AjaxPostBack procedure that runs on the server like the one shown below?
Best Regards,
Vincent
protected void Map1_AjaxPostback(object sender, AjaxPostbackEventArgs e)
switch (e.EventName)
case "ZoomIn":
Map1.ZoomIn(40);
break;
case "ZoomOut":
Map1.ZoomOut(40);
break;
case "PanLeft":
Map1.Pan(PanDirection.Left, 20);
break;
Hello Vincent,
Thanks for your post, you can check this post to refer how to let Ajax working, then put the logic above into  ////do sever side processing here
