Another popup question
I have an application where I show popups… I do have the close popup property = true…  depending which popup I want to close using the close button, I have to click many times the close button of a popup before having the popup closed…  looks like that the number of clicks is linked with the number of popup on the map…  If I have 7 open popups then to close the popup number 7 I have to click the close popup button 7 times to close the popup?
thanks.
jm.
Hi Jean-marie,
 I add multiply CloudPopup in controller, then click close button to close them, it looks each click can close one popup.
 So I cannot reproduce your issue, please let me know if I miss anything or some code need be changed for test.
