Arc\Info ASCII grid
Anyone has any ideas how to load an Arc\Info ASCII grid?
I am using the following code:
GdalRasterLayer grl = new GdalRasterLayer(@“C:!Daniel\MNR\ZDT\Simulations\Raster Files\bp10k.txt”);
staticOverlay.Layers.Add(“Grid View”, grl);
// Draw the map.
winformsMap1.Refresh();
I am attaching the example file to this post.
bp10k.txt (65.8 KB)
Hi Daniel,
The format can be supported by GdalRasterLayer, you can invoke GdalRasterLayer as following statements:
        GdalRasterLayer rasterLayer = new GdalRasterLayer(@"C:\Temp\bp10k.txt");
        rasterLayer.Open();
        RectangleShape rect = rasterLayer.GetBoundingBox();
        winformsMap1.CurrentExtent = rect;
        overlay.Layers.Add(rasterLayer);
        winformsMap1.Overlays.Add(overlay);
Don,
Thanks for your sample code. I realized I did not have the MapSuiteFdoExtensionX64 files copied to the System32. After I did this all was good. I have a couple more questions.
  1. Is there a way to colorized class breaks. At the moment is showing an ugly black and white grid. [image][1]
    [1]: http://screencast.com/t/cr0uPa39LYp I would like to see something more like this [image][2] [2]: http://screencast.com/t/m2e6W1g5Rj with a legend.
  2. could you let me know what tools I could use to select a region on the map and then reclassify the selected area?
  3. In the NativeTabFileSupport example, there is a save option. Do you think something similar can be implemented for the ASCII Grid format?
Please let me know if this is something that I need to discuss with the dev team.
Daniel
Hi Daniel_Kaminski,
Thanks for your questions.
The colorized class breaks feature is a new feature for us, so it’s not supported by “MapSuiteFdoExtension”.
But I think it can be supported if we research a period of time. Support it and edit an arc/info file mentioned in your other two questions, they should be professional services, so you can contact sales@thinkgeo.com for detail, so that we can make some formal new features development.
Thank,
Thanks Don. I will get in touch with Dev team and see what they say about my requests.
Hi Daniel_Kaminski,
Any update please feel free to let us know.
