New to Map Suite. Wondering the questions below:
What is the overall architecture of the product?
tile based? or map generated as one image and deliver to the client? or rendered as vector?
can filter spatial data based on non-spatial attributes?
can dynamically assign styles/labeling rules to layers to generate maps on the fly?
can specify different non-spatial attributes for styling/labeling on the fly?
can export map for printing including basemap, user layers (vector, raster), and in-memory layers?
thanks,
Architecture and features question
I don’t posse much information related to it but one thing which I know about it is that it does not dynamically assign styles/labeling rules to layers to generate maps on the fly and you cannot export map for printing including basemap, user layers (vector, raster), and in-memory layers.
You can check it out at 3d printing metal.
Hi GuangMing,
Thanks for interested in our product.
The MVC map based on other products of ThinkGeo, mainly functions supported by MapSuiteCore.
It’s tile based.
Our feature can save non-spatial information in columnvalues, we can filter shape data based on the values.
Our map can dynamically change styles to generate maps on the fly, you only need “refresh” the map after that or Pan/Zoom.
can specify different non-spatial attributes for styling/labeling on the fly? Do you means we can change the non-spatial attributes on the fly and then render the shapes and labels based on the changed value? If so I think we support that also, just like the previous item.
Our map support printing, but for some special layers, for example GoogleOverlay, we need use GoogleMapslayer instead of it when print.
Wish it’s helpful.
