ArgumentOutOfRange exception using GetFeaturesWithinDistanceOf
I have tested this with the Daily Development Build 5.5.26.0 and also with the latest production release version 5.5.0.0.
The error only happens under certain circumstances.
  1. There is a layer in a geographic coordinate system, NAD83, units of decimal degree.
  2.
  3. This layer is projected to a different (projected) coordinate system, NAD83 Zone 16N.
  4.
  5. A feature in the layer is edited and the transaction remains open.
  6.
  7. After the edit occurs any attempt to use GetFeaturesWithinDistanceOf results in an ArgumentOutOfRange exception.
System.ArgumentOutOfRangeException was unhandled
  Message=The decimal degree longitude value you provided was out of range.
Parameter name: fromLongitude
  ParamName=fromLongitude
  Source=MapSuiteCore
  StackTrace:
       at exQ=.cTs=.xzs=(Double yDs=, String yTs=)
       at ThinkGeo.MapSuite.Core.DecimalDegreesHelper.GetDistanceFromDecimalDegrees(Double fromLongitude, Double fromLatitude, Double toLongitude, Double toLatitude, DistanceUnit returningUnit)
       at ThinkGeo.MapSuite.Core.DecimalDegreesHelper.B0c=(Double CEc=, Double CUc=, Double Ckc=, Double C0c=, PointShape DEc=, DistanceUnit DUc=)
       at ThinkGeo.MapSuite.Core.LineShape.mU4=(PointShape wFI=, GeographyUnit wVI=, DistanceUnit wlI=, PointShape& w1I=, Double& xFI=)
       at ThinkGeo.MapSuite.Core.LineShape.GetDistanceToCore(BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit)
       at ThinkGeo.MapSuite.Core.BaseShape.GetDistanceTo(BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit)
       at ThinkGeo.MapSuite.Core.PolygonShape.GetDistanceToCore(BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit)
       at ThinkGeo.MapSuite.Core.MultipolygonShape.GetDistanceToCore(BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit)
       at ThinkGeo.MapSuite.Core.FeatureSource.GetFeaturesWithinDistanceOf(BaseShape targetShape, GeographyUnit unitOfData, DistanceUnit distanceUnit, Double distance, IEnumerable`1 returningColumnNames)
       at ThinkGeo.MapSuite.Core.FeatureSource.GetFeaturesWithinDistanceOf(BaseShape targetShape, GeographyUnit unitOfData, DistanceUnit distanceUnit, Double distance, ReturningColumnsType returningColumnNamesType)
       at ThinkGeo.MapSuite.Core.QueryTools.GetFeaturesWithinDistanceOf(BaseShape targetShape, GeographyUnit unitOfData, DistanceUnit distanceUnit, Double distance, ReturningColumnsType returningColumnNamesType)
       at DeleteTest.Form1.WinformsMap1_MapClick(Object sender, MapClickWinformsMapEventArgs e) in C:\Users\steller\Documents\Visual Studio 2010\Projects\ThinkGeo\DistanceSearchProjectedDegrees\Form1.vb:line 125
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.OnMapClick(MapClickWinformsMapEventArgs e)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.KhY=(InteractionArguments KxY=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.EBY=(Object ERY=, 6Bc= EhY=)
       at 8BM=.jhU=.OnMouseEvent(6Bc= e)
       at 8BM=.jhU=.uRU=(Object uhU=, EventArgs uxU=)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at DeleteTest.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
  InnerException:
This is not a problem if the transaction is committed following the edit. It is also not a problem if the layer is not projected into a different coordinate system.
I have attached a sample project, please let me know if this is a bug or if I'm just not doing something right.
Steve
DistanceSearchProjectedDegrees.zip (30.5 KB)
Steve,
 Thanks for the sample app and reporting the issue, I was able to recreate it and believe it’s a bug.  I will have the development team take a look at it and let you know what they find.
 Steven,
The bug has been confirmed and will be fixed in tomorrow's daily build (5.5.34.0). Thanks very much for your sample and the detailed description which helps us a lot to recreate it.
Hi Ben,
 Thanks for the quick reply. Will this bug fix be in the Daily Production Build as well? The Development build is a little too unstable for us right now.
 Steve
Steve,
 Sure. It is fixed in Production Build and please try 5.5.0.35 or later.
Ben,
 Thanks for the fix. It is working now.
 Steve
Thanks for reporting the issue and providing the sample Steve!
