Avoid Map Refresh on Click
I'm testing the Web Edition and I'm having some troubles everytime I click on the map. Everytime that I click somewhere on the map, the whole page is refreshed without any reasons... I have nothing in the method "OnClick" however.
By the way, I'm using the GoogleMap layer
Here is my code.
The control:
<cc1:Map ID="MyMap" runat="server" Height="680px" Width="1600px" OnClick="Map_Click">
The declaration of my map
 try
                if (!IsPostBack)
                    MyMap.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.FromHtml("#E5E3DF"));
                    MyMap.CurrentExtent = new RectangleShape(-125, 72, 50, -46);
                    MyMap.MapUnit = GeographyUnit.Meter;
                //initialization
                    var currentMap = new Map();
                    MyMap.MapTools.OverlaySwitcher.Enabled = true;
                    MyMap.MapTools.AnimationPanMapTool.Enabled = true;
                    //Map1.MapTools.TouchMapTool.Enabled = true;
                    MyMap.MapTools.MouseCoordinate.Enabled = true;
                    MyMap.CustomOverlays.Add(currentMap.GoogleOverlay);
                    MyMap.CustomOverlays.Add(currentMap.StaticOverlay);
                    //Map1.CustomOverlays.Add(dynamicOverlay);
                initialize();
            catch (Exception ex)
 protected void Map_Click(object sender, MapClickedEventArgs e)
The creation of the "layers" + "overlays", Class Map.cs
 public Map()
            InitGoogleOverlay();
            InitStaticOverlay();
        private void InitGoogleOverlay()
            var googleOverlay = new GoogleOverlay("Google Map");
            googleOverlay.GoogleMapType = GoogleMapType.Normal;
            GoogleOverlay = googleOverlay;
 private void InitStaticOverlay()
            LayerOverlay staticOverlay = new LayerOverlay(STAT_OVERLAY, true, TileType.SingleTile);
            //LayerOverlay staticOverlay = new LayerOverlay(STAT_OVERLAY);
            staticOverlay.Layers.Add(WORLD_LAYER, WorldLayer());
            staticOverlay.IsBaseOverlay = false;
            StaticOverlay = staticOverlay;
  private ShapeFileFeatureLayer WorldLayer()
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(COUNTRY_FILE_PATH);
            AreaStyle areaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.Green));
            worldLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(areaStyle);
            //use the projection to keep the shape file working with google map
            worldLayer.FeatureSource.Projection = proj4;
 worldLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(valueStyle);
            return worldLayer;
Does anybody have already got this issue ??
Hello Patrick,
 The problem is you are using:
And this code will cause the client side request the server side, because "runat=server", you can using ajax to avoid this.
