Are you assuming that there is a row that is unique?
I have looked through the datatable that was returned by the query, and only the we created was there and there is not a row that is unique. I realize we should have some sort of ID row, and I normally would if I was linking my shapes to an external datasource. however when I'm working directly with a shapefile and not linking it externally we don't always create a unique identifier row, as as far as my understanding of shape files go, there is a a link to the attribute data based on the shapes index in the shape file and the row number in the attribute file.
Having said that, I realized that its not actually necessary to use a unique identifier row to link to the data, as I can actually use the column I am searching. Below is the modified version of your code
        public static Collection<feature> QueryFeatures(ShapeFileFeatureLayer layer, string ColumnName, string Criteria)         {             string strSQL = string.Empty;             string strCriteria = string.Empty;              if (Criteria.Contains("*"))             {                 strCriteria = Criteria.Replace("*", "%");                 strSQL = String.Format("SELECT * FROM {0} WHERE {1} LIKE '{2}'", Path.GetFileNameWithoutExtension(layer.ShapePathFileName), ColumnName, strCriteria);             }             else             {                 strCriteria = Criteria;                 strSQL = string.Format("SELECT * FROM {0} WHERE {1} = '{2}'", Path.GetFileNameWithoutExtension(layer.ShapePathFileName), ColumnName, strCriteria);             }              layer.Open();             DataTable dataTable = layer.QueryTools.ExecuteQuery(strSQL);             layer.Close();              Collection<feature> returnFeatures = new Collection<feature>();             if (dataTable.Rows.Count > 0)             {                 foreach (DataRow dataRow in dataTable.Rows)                 {                     string recId = dataRow[ColumnName].ToString();                     Collection<feature> tempFeatures = layer.FeatureSource.GetFeaturesByColumnValue(ColumnName, recId);                     if (tempFeatures.Count != 0)                     {                         foreach (Feature featureResults in tempFeatures)                             if (!returnFeatures.Contains<feature>(featureResults))                                 returnFeatures.Add(featureResults);                     }                 }             }              return returnFeatures;         }
I realize this is more modified for my solution, however if you are looking at wrapping a similar sort of query function into map suite, you may want to keep in mind that there is not necessarily a unique column created in the attribute table.
I appologize if I am incorrect in this statement.
Anyway. Thanks for the code above though. This should solve my problem.
