Bad behavior by IconStyle in MapPrinterLayer
Hi guys,
Recently I did some work with the IconStyle to create highway numbers for road layers. Everthing worked as expected in the WinFormsMap. However, when I switched to our Page Layout map I began to get an Argument exception. Here is the stack trace:
System.ArgumentException was unhandled
  Message=Parameter is not valid.
  Source=System.Drawing
  StackTrace:
       at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
       at System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
       at ThinkGeo.MapSuite.Core.GeoCanvas.DrawScreenImageWithoutScaling(GeoImage image, Single centerXInScreen, Single centerYInScreen, DrawingLevel drawingLevel, Single xOffset, Single yOffset, Single rotateAngle)
       at ThinkGeo.MapSuite.Core.GeoCanvas.DrawWorldImageWithoutScaling(GeoImage image, Double centerXInWorld, Double centerYInWorld, DrawingLevel drawingLevel, Single xOffset, Single yOffset, Single rotateAngle)
       at ThinkGeo.MapSuite.Core.GeoCanvas.DrawWorldImageWithoutScaling(GeoImage image, Double centerXInWorld, Double centerYInWorld, DrawingLevel drawingLevel)
       at ThinkGeo.MapSuite.Core.IconStyle.tRM=(GeoImage siQ=, Feature syQ=, GeoCanvas tCQ=, Int32 tSQ=, Int32 tiQ=, Collection`1 tyQ=, Collection`1 uCQ=)
       at ThinkGeo.MapSuite.Core.IconStyle.DrawCore(IEnumerable`1 features, GeoCanvas canvas, Collection`1 labelsInThisLayer, Collection`1 labelsInAllLayers)
       at ThinkGeo.MapSuite.Core.Style.Draw(IEnumerable`1 features, GeoCanvas canvas, Collection`1 labelsInThisLayer, Collection`1 labelsInAllLayers)
       at ThinkGeo.MapSuite.Core.ZoomLevel.DrawCore(GeoCanvas canvas, IEnumerable`1 features, Collection`1 currentLayerLabels, Collection`1 allLayerLabels)
       at ThinkGeo.MapSuite.Core.ZoomLevel.Draw(GeoCanvas canvas, IEnumerable`1 features, Collection`1 currentLayerLabels, Collection`1 allLayerLabels)
       at ThinkGeo.MapSuite.Core.FeatureLayer.DrawCore(GeoCanvas canvas, Collection`1 labelsInAllLayers)
       at ThinkGeo.MapSuite.Core.MapPrinterLayer.DrawCore(GeoCanvas canvas, Collection`1 labelsInAllLayers)
       at ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay.DrawCore(GeoCanvas canvas)
       at ThinkGeo.MapSuite.DesktopEdition.Overlay.kBQ=(GeoCanvas kRQ=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.NxQ=(RectangleShape FBg=, Overlay FRg=, Int32 Fhg=, Int32 Fxg=, GeographyUnit GBg=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.LBQ=(IEnumerable`1 Ghg=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.HBQ=()
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.GBQ=(Int32 CRg=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.ERQ=(InteractionArguments BBg=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.8xM=(Object 6hc=, 4xU= 6xc=)
       at QRQ=.5xQ=.OnMouseEvent(4xU= e)
       at QRQ=.5xQ=.DxU=(Double EBU=, Double ERU=, Double EhU=, Double ExU=, Int32 FBU=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.ARg=(Object Ahg=, MouseEventArgs Axg=)
       at System.Windows.Forms.Control.OnMouseWheel(MouseEventArgs e)
       at System.Windows.Forms.Control.WmMouseWheel(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at ScaleBarTest.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
I decided to put together a sample project to attach to this post. In preparing the project I noticed that if I set the IconImageScale property of the IconStyle to something other than 1 (the default) the IconStyle would draw and no longer produce the error. But even though setting the IconImageScale to something other than 1 causes the IconStyle to draw, it now draws outside of the boundaries of the MapPrinterLayer.
I have attached a sample project so you can easily see the problem.
Steve
001_Icon_Labels_In_Page_Layout.zip (184 KB)
Steven,
 Thank you for the detailed explanation and well documented sample app. The problem has been clearly identified. This problem has been added to our Issue Tracker and the Development Team will work on that next week. I will let you know as soon as we have a fix for this.
Steven,
 We fixed the problem and personally verified this testing with the sample that you sent us. You will need to get the Dev build 5.5.119.0 or later. Thank you for reporting the problem and helping us make our products better.
Val,
 Thanks Very Much!
 Do you know when the fix will be available in a production build?
 Steve
Steven,
 It should be in the Bug build on Monday. The Development Team forgot to include the fix in the Bug build (production) and I reminded them. Thank you.
Steven,
  I would like to precise that until now only the DEV branch is updated unless the user specifically requires the changes on the BUG build as well. However, since starting in May, we will have the yearly release instead of the 6 month release, we will start making the fixes to every build. Thank you.
Val,
 Thanks for the clarification.
Steven,
 You are welcome.
Val.
