Basic map
I am starting to convert from V2 to 3 of desktop )-:
Are there any examples for V3.0 to do all of the following menu items ? In particular Map.CurrentExtent = Map.FullExtent
Regards
Ewan
The following code is from V2
Select Case e.Button.ToolTipText
            Case "Track Zoom In"
                mapToolBar.Buttons(0).Pushed = True
                Map.Mode = ModeType.TrackZoomIn
                Exit Select
            Case "Zoom In"
                Map.ZoomIn(40)
                Exit Select
            Case "Zoom Out"
                Map.ZoomOut(40)
                Exit Select
            Case "Full Extent"
                Exit Select
            Case "Toggle Extent"
                Map.ToggleMapExtents()
                Exit Select
            Case "Previous Extent"
                Map.GetPreviousExtent()
                Exit Select
            Case "Pan"
                mapToolBar.Buttons(8).Pushed = True
                Map.Mode = ModeType.Pan
                Exit Select
            Case "Pan Left"
                Map.Pan(PanDirection.Left, 20)
                Exit Select
            Case "Pan Right"
                Map.Pan(PanDirection.Right, 20)
                Exit Select
            Case "Pan Up"
                Map.Pan(PanDirection.Up, 20)
                Exit Select
            Case "Pan Down"
                Map.Pan(PanDirection.Down, 20)
                Exit Select
            Case "Print Preview"
                Dim PrintPreview As New PrintPreviewDialog()
                Map.PrintDocument.DefaultPageSettings.Landscape = True
                PrintPreview.Document = Map.PrintDocument
                PrintPreview.ShowDialog()
                Exit Select
            Case "Open Map"
end select
Ewan, Welcome you to ThinkGeo MapSuite Desktop Edition Forum!
MapSuite 3.0 is much more powerful than MapSuite2.0 with its widely supports all kinds of layers, while NOT all kinds of layer has bounding box for it.
So In MapSuite3.0, We do not support FullExtent anymore, if you want, you can write the logic your self as following way:
winformsMap1.CurrentExtent = GetFullExtent()
Private Function GetFullExtent() As RectangleShape
            Dim boundingBox As RectangleShape = Nothing
            For Each Overlay In winformsMap1.Overlays
                If TypeOf (Overlay) Is LayerOverlay Then
                    Dim layerOverlay As LayerOverlay = DirectCast(Overlay, LayerOverlay)
                    For Each layer As Layer In layerOverlay.Layers
                        If layer.HasBoundingBox Then
                            If Not layer.IsOpen Then
                                layer.Open()
                            End If
                            If boundingBox Is Nothing Then
                                boundingBox = layer.GetBoundingBox()
                            Else
                                boundingBox.ExpandToInclude(layer.GetBoundingBox())
                            End If
                        End If
                    Next
                End If
            Next
            Return boundingBox
        End Function
Let me know if any more questions.
Thanks - this was helpful but I still only seem to be able to render the image to show at about 50% its size in the control.
 ie the world map only show 1/2 size despite the bounding box upper left and lower right properties being at the world extents ??
 Ewan
Ewan,
Thanks for your post and question!
The reason for this is the “Snapping” behavior changed the extent somehow, our default will shown contains 20 preset scales for better caching effects. If you set an extent just between the middle of 2 preset “Scales” (bounding box upper left and lower right of the world extent), it will snap to some preset one (1/2 size).
If you want, you can set different snapping mode and have a try:
winformsMap1.ZoomLevelSnapping = ZoomLevelSnappingMode.None;
