Beta 2 - ContextMenuItem Click Events and InnerHtml
Downloaded and installed the new Beta version this morning.  The following was working with the original Beta.
Created a ContextMenuItem with the Item containing a reference to columndata (using format [#columndatafieldname#].  Also creating a click event for the item.
When the click even occurs and is triggered on the server, the text in the events InnerHtml property contains the [#columndatafieldname#] syntax and not the actual column data.  One thing to note is that the contextmenu item does display correctly when the contextmenu is displayed on the Map.
ContextMenuItem
 contextMenuItem = (ContextMenuItem)e.ClickTarget;
contextMenuItem.InnerHtml
Tony,
 Thanks for reporting this. It is a bug and we will fix it in the next version.
