Hi, Support I was wondering if there was a way to add zoom levels onto Bing maps. We have successfully dont it to goolge maps but i was wondering if it was possible with bing i tried to convert the code to use the bing map instead of googles but with no luck
Client Side
function OnOverlaysDrawing(layers) {
for (var index = 0; index < layers.length; index++) { var templayer= layers[index]; if (OpenLayers.String.contains(templayer.CLASS_NAME, ‘Bing Map’)) //if (OpenLayers.String.contains(templayer.CLASS_NAME.indexOf(‘Bing’) > 0)) { templayer.options.numZoomLevels = 0; templayer.options.maxZoomLevels = 20;
This function require server support, if Google can implement that, I think that’s because google support return any scale tile, if we want move that to Bing, we need Bing support custom zoom level.
Image likes this means Bing Maps has not map data here. This usually occurs when the map extent is in ocean and zoom level is pretty deep. The land area of zoom level 19 should be OK.
BTW, we can try Google maps, those ocean area will also be rendered out.
