We tried to use BingMap Background in our application, and because some our customer have web-Proxy, we assigned WebProxy to proxy property of layer.
Problem is that it’s not stable on our client machine, sometimes working find and and throwing Exception on the other time?
1- why it’s not stable?(sometimes working find and not working on the other time)
2- I attached a small application which shows how we use background, is there any problem in the way we call background?
Behnam
exception:
Exception classes:
System.Net.WebException
Exception messages:
The remote server returned an error: (407) Proxy Authentication Required.
Stack Traces:
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.<>c__DisplayClass6.<DrawException>b__4()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
ThinkgeoWms.zip (37.2 KB)
BingMap Background
Hi Behnam,
Since you have recreated a ticket for this issue, we will reply it in the ticket system. But in case other guys encounter a same issue, I will update here once we resolve it.
