BingTileOverlay
Hi Guys,
I am trying to use the BingMapsTileOverlay. I see that you also have a BangMapOverlay but I am getting errors when I try to use that while the BingMapsTileOverlay does seem to work as far as bringing up a roadmap. But I am finding with the BingMapsTileOverlay that  the MapStyle property doesn't seem to be working when it is set to anything other then RoadMap.
This is the code:
BingMapsTileOverlay
 bingMapsOverlay = new BingMapsTileOverlay("our key");
bingMapsOverlay.MapStyle =
bingMapsOverlay.LogoMode =
_map.Overlays.Add(
BingMapsMapType.Aerial;BingMapsLogoMode.NoLogo;"BING", bingMapsOverlay);
Chris
That code didn’t paste in correctly but there isn’t anything to it anyway-
 BingMapsTileOverlay bingMapsOverlay =
                 new BingMapsTileOverlay(“our key”);
             bingMapsOverlay.MapStyle = BingMapsMapType.Aerial;
             bingMapsOverlay.LogoMode = BingMapsLogoMode.Default;
             _map.Overlays.Add(“BING”, bingMapsOverlay);
Hello Christopher.
 Which version are you using? In our newest version, we don’t have MapStyle anymore, instead it we are using
  bingMapsOverlay.MapType = BingMapsStyle.Aerial;
 Could you please update to the new version and have a try?
Hi Gary,
 So this is interesting I made the change that I think you are suggesting here is the code now -
 BingMapsOverlay bingMapsOverlay =
                 new BingMapsOverlay(“our key”);
 bingMapsOverlay.MapType = BingMapsMapType.Aerial;
 bingMapsOverlay.CacheDirectory = @“C:\Temp\BING”;
 This does seem to work as far as downloading tiles to the specified tile cache but as soon as I start panning I get this error -
 The process cannot access the file ‘C:\Temp\BING\BingMapsMetadata.xml’ because it is being used by another process.
 I am using version 5.5.0.96 of the wpf desktop edition.
 And here is the call stack -
 > mscorlib.dll!System.IO.__Error.WinIOError(int errorCode = -2147024864, string maybeFullPath = “C:\Temp\BING\BingMapsMetadata.xml”) + 0x321 bytes
   mscorlib.dll!System.IO.FileStream.Init(string path, System.IO.FileMode mode, System.IO.FileAccess access = Write, int rights, bool useRights = false, System.IO.FileShare share, int bufferSize = 4096, System.IO.FileOptions options, Microsoft.Win32.Win32Native.SECURITY_ATTRIBUTES secAttrs, string msgPath, bool bFromProxy, bool useLongPath) + 0x477 bytes
   mscorlib.dll!System.IO.FileStream.FileStream(string path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) + 0x54 bytes
   System.Xml.dll!System.Xml.XmlDocument.Save(string filename) + 0x8b bytes
   MapSuiteCore.dll!ThinkGeo.MapSuite.Core.BingMapsLayer.KVw=(string Klw= = “C:\Temp\BING\BingMapsMetadata.xml”) + 0x185 bytes
   MapSuiteCore.dll!ThinkGeo.MapSuite.Core.BingMapsLayer.KFw=() + 0xa2 bytes
   MapSuiteCore.dll!ThinkGeo.MapSuite.Core.BingMapsLayer.OpenCore() + 0x3d bytes
   MapSuiteCore.dll!ThinkGeo.MapSuite.Core.Layer.Open() + 0x3a bytes
   WpfDesktopEdition.dll!ThinkGeo.MapSuite.WpfDesktopEdition.LayerTile.DrawCore(ThinkGeo.MapSuite.Core.GeoCanvas geoCanvas = {ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas}) + 0x257 bytes
   WpfDesktopEdition.dll!ThinkGeo.MapSuite.WpfDesktopEdition.Tile.Draw(ThinkGeo.MapSuite.Core.GeoCanvas geoCanvas = {ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas}) + 0xbd bytes
   WpfDesktopEdition.dll!ThinkGeo.MapSuite.WpfDesktopEdition.Tile.KxU=(object LBU= = {ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas}) + 0xe6 bytes
   mscorlib.dll!System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(object state) + 0x2d bytes
   mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool ignoreSyncCtx) + 0xb0 bytes
   mscorlib.dll!System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() + 0x5a bytes
   mscorlib.dll!System.Threading.ThreadPoolWorkQueue.Dispatch() + 0x147 bytes
   mscorlib.dll!System.Threading._ThreadPoolWaitCallback.PerformWaitCallback() + 0x2d bytes
 Chris
Also if I run the app and then let it try and load the tiles without doing any panning, most of the tiles will show up but then I will get  this error -
Parameter is not valid.
here is the callstack -
 System.Drawing.dll!System.Drawing.Bitmap.Bitmap(string filename) + 0x86 bytes
  MapSuiteCore.dll!ohM=.S14=.Ohw=(object n14= = {System.Drawing.Graphics}) + 0xc7 bytes
Hello Christopher,
 Thanks for your further information.
 Are you using multipletile like: bingMapsOverlay.TileType = TileType.MultipleTile ?
 Sorry I can’t recreate your problem, your code didn’t have any problem, could you please provide a self-contained sample that can recreate the problem?
 Thanks for your help and patience.
