I’ve noticed that if I try and create a buffer on a polygon with a Square buffer cap that you end up getting the same result as if I used the Round option.
Also, buffer option for a point using Butt produces a null object. I think at the least it should just return the point.
Attached is a test project. I am using version 9.0.632.0.
Can you please look into this fix?
BufferTesting.zip (43.8 KB)
Damian
