Bug in method GetPointOnALine?
I find something really strange. In my original code the method GetPointOnALine in some cases returns a wrong point. I make a code test for document this issue but the result is diferent in the test code??? The result in both cases is wrong.
Here is the test code:
Imports ThinkGeo.MapSuite.Core
Imports ThinkGeo.MapSuite.DesktopEdition
Public Class Form1
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim omsmlsMLine As MultilineShape
        Dim omspsPoint As PointShape
        omsmlsMLine = New MultilineShape("MULTILINESTRING((660081.58593899 2178301.72641268,660081.598276218 2178308.96236724))")
        omspsPoint = omsmlsMLine.GetPointOnALine(StartingPoint.FirstPoint, 50)
        ' In my original code returns "POINT(660081.58593899 2178301.72641265)" a diferent result from this test code but
        ' both incorrect ????
        MsgBox("Incorrect middle point calculated: " + omspsPoint.GetWellKnownText() + vbCrLf + _
               "The correct point is: POINT(660081.5921 2178305.344)", MsgBoxStyle.Critical, "Error")
    End Sub
End Class
It is a bug? Am I doing something wrong?
I found other case more strange. But the problem is that it can not be replicable via the WellKnownText, becouse in this way the result is ok. But I send you the results that I have in the command window when I was debuging.
>? omsmlsEje.GetWellKnownText()
"MULTILINESTRING((660858.341603156 2178891.39187658,660826.776988299 2178770.71526703,660800.705646911 2178648.73389893))"
>? omsmlsEje.GetPointOnALine(StartingPoint.FirstPoint, 50).GetWellKnownText()
"POINT(660858.341603156 2178891.39187658)"
It's returning the first point?? but why if I use the WKT to create again the shape works fine??
Yuri,
 Thanks for your reporting! This is a bug in MapSuite Core, I have added this to our working system, and hopefully it will be fixed in next version.
 If you want to get the center point, please use the GetCenterPoint instead.
I also ran into this problem.  I'm trying to get a point 100 meters from the start of the line.  Will this fix make it into the next release and, if so, when?
Yuri and David,
 We will release a new version next Monday in which the problem has been solved, just wait a couple days and try.
