Unfortunately i cant send the whole code because im using postgresql database for my layers, but i can send the partial code.
    protected override Task DrawTileAsyncCore(GeoCanvas geoCanvas)
        geoCanvas.DrawingQuality = DrawingQuality.HighSpeed;
        bool show_pointer = false;
        if (!mainWindow.IsNewFeatureActive)
            return base.DrawTileAsyncCore(geoCanvas);
        if (mainWindow.GetLayerActive().ShapeType is PointShape)
            if (Point_feature != null)
                if (mainWindow.GetLayerActive().Input.InputType == "SimplePoint")
                    foreach (FeatureCollection featureCollection in mainWindow.TempFeatureCollection)
                        if (featureCollection.IsSelected)
                            geoCanvas.DrawEllipse(featureCollection.BaseShape.GetCenterPoint(), 3.0f, 3.0f, new GeoPen(new GeoColor(255, GeoColors.BrightYellow), 4.0f), DrawingLevel.LevelOne);
                        else
                            geoCanvas.DrawEllipse(featureCollection.BaseShape.GetCenterPoint(), 3.0f, 3.0f, new GeoPen(new GeoColor(255, GeoColors.Aqua), 3.0f), DrawingLevel.LevelOne);
                        geoCanvas.DrawTextWithScreenCoordinate($"{featureCollection.FeatureLabel}", new GeoFont("Segoe UI", 10.0f, DrawingFontStyles.Bold), GeoBrushes.DarkRed, new GeoPen(GeoColor.FromHtml("#FFFFFF"), 1.5f), (float)MapUtil.ToScreenCoordinate(featureCollection.BaseShape, mapView.CurrentExtent, (float)mapView.ActualWidth, (float)mapView.ActualHeight).GetCenterPoint().X, (float)MapUtil.ToScreenCoordinate(featureCollection.BaseShape, mapView.CurrentExtent, (float)mapView.ActualWidth, (float)mapView.ActualHeight).GetCenterPoint().Y - 10, DrawingLevel.LevelOne);
                    geoCanvas.DrawEllipse(Point_feature, 3.0f, 3.0f, new GeoPen(new GeoColor(255, GeoColors.BrightRed), 3.0f), DrawingLevel.LevelOne);
                if (mainWindow.GetLayerActive().Input.InputType == "Image")
                    if (!is_edit)
                        geoCanvas.DrawWorldImage(new GeoImage(@"Assets/DT_RIGHT_CYAN.png"), Point_feature.GetShape().GetCenterPoint().X, Point_feature.GetShape().GetCenterPoint().Y, 24, 24, DrawingLevel.LevelFour, 0, 0, 0);
                    else
