Bug?
I had an issue with a simple application showing a heat map.   At first I define inside the view / map / CustomOverlays my layeroverlay and my layer heat map.  But when running the application I was always getting a message like object not defined visible only for few milliseconds and then the application was just running OK.  Then I try to define the layer overlay inside the view and the heat layer inside the controller. Doing so removed the initial error.....  I was unable to trap the error when using the view to define both overlay and layer.  maybe there is a bug ....
The heat layer was populated using the ajax way...   I mean that just having the layeroverlay and heat layer was enough to see rhe error message and of course the error message was visible when I  disabled the call to populate the heat layer using Ajax.
Do you think that if we have to use  a view we have not only to define the layeroverlay and heat layer but also we have to populate / load  the heat layer with data points????
thanks.
 Map2.ajaxCallAction(_controllerId, 'getHeat', {}, function (result) {
        var _r = result.get_responseData();
        var format = new OpenLayers.Format.WKT();
        var feature = format.read(_r).geometry;
        Map2.zoomToExtent(feature.getBounds());
        Map2.redrawLayer('Heat');
                    Html.ThinkGeo().Map("Map2", System.Web.UI.WebControls.Unit.Percentage(100), System.Web.UI.WebControls.Unit.Percentage(100))
                    .MapBackground(new BackgroundLayer(new GeoSolidBrush(GeoColor.StandardColors.White)))
                    .CurrentExtent(-14148507.181077, 6271924.7354557, -5114687.7715466, 3097880.0780531)
                    .MapUnit(GeographyUnit.Meter)
                    .MapTools(mapTools =>
                    mapTools.MouseCoordinateMapTool().Enabled(false);
                    mapTools.PanZoomBarMapTool().Enabled(false);
                    mapTools.LoadingImageMapTool().Enabled(false);
                    mapTools.TouchMapTool().Enabled(true);
                    mapTools.MouseMapTool().Enabled(true);
                    mapTools.KeyboardMapTool().Enabled(false);
                    mapTools.ScaleLineMapTool().Enabled(false);
                    mapTools.PanZoomMapTool().IsGlobeButtonEnabled(false).Enabled(false);
                .CustomOverlays(overlays =>
                    overlays.WmsOverlay("WMS Overlay")
                        .Parameters(paras =>
                            paras.Add("LAYERS", "WorldMapKitRL_SPHMCT");
                            paras.Add("STYLES", "DEFAULT");
                            paras.Add("SRS", "EPSG:4326");
                            .ServerUris(uris =>
                                for (int x = 0; x <= 4; x++)
                                    uris.Add(new Uri("GEOWMS.USAC.MMM.COM:80/WmsHandler.axd"));
                                    uris.Add(new Uri("GEOWMS.USAC.MMM.COM:81/WmsHandler.axd"));
                                    uris.Add(new Uri("GEOWMS.USAC.MMM.COM:82/WmsHandler.axd"));
                                    uris.Add(new Uri("GEOWMS.USAC.MMM.COM:83/WmsHandler.axd"));
                                    uris.Add(new Uri("GEOWMS.USAC.MMM.COM:84/WmsHandler.axd"));
                                    uris.Add(new Uri("GEOWMS.USAC.MMM.COM:85/WmsHandler.axd"));
                                    uris.Add(new Uri("GEOWMS.USAC.MMM.COM:86/WmsHandler.axd"));
                                    //uris.Add(new Uri("GEOWMS.USAC.MMM.COM:87/WmsHandler.axd"));
                                    //uris.Add(new Uri("GEOWMS.USAC.MMM.COM:88/WmsHandler.axd"));
                            .TileType(TileType.SingleTile)
                            .IsBaseOverlay(true);
                    //HeatLayer Heat = new HeatLayer();
                    //Heat.Name = "Heat";
                    //Heat.IsVisible = true;
                    overlays
                     .LayerOverlay("HeatOverlay")
                     .Name("HeatOverlay")
                     .IsBaseOverlay(false)
                     .TileType(TileType.SingleTile);
                    //overlays
                    // .LayerOverlay("HeatOverlay").Name("HeatOverlay").IsBaseOverlay(false)
                    //    .Layer("Heat", Heat).TileType(TileType.SingleTile);
                .Render();
   GeoKeyedCollection<Overlay> _overlays = map.CustomOverlays;
            LayerOverlay _layerOverlay = (LayerOverlay)_overlays["HeatOverlay"];
            //HeatLayer heatLayer = (HeatLayer)_layerOverlay.Layers["Heat"];
            //LayerOverlay __layerOverlay = new LayerOverlay();
            //__layerOverlay.Name = "HeatOverlay";
            //__layerOverlay.IsBaseOverlay = false;
            //__layerOverlay.IsVisible = true;
            HeatLayer __heatLayer = new HeatLayer();
            _layerOverlay.Layers.Add(__heatLayer);
            InMemoryFeatureSource _featureSource = new InMemoryFeatureSource(this.FeatureSourceColumns(_features[0]), _features);
            _featureSource.Open();
            _featureSource.BuildIndex();
            HeatStyle heatStyle;
            heatStyle = new HeatStyle();
            heatStyle.RequiredColumnNames.Add("sales");
            heatStyle.IntensityColumnName = "sales";
            heatStyle.IntensityRangeStart = 1.00D;
            heatStyle.IntensityRangeEnd = 100000000.00D;
            heatStyle.Alpha = 128;
            heatStyle.PointIntensity = 512;
            heatStyle.PointRadius = (double)10000D;
            heatStyle.PointRadiusUnit = DistanceUnit.Meter;
            __heatLayer.HeatStyle = heatStyle;
            __heatLayer.Name = "Heat";
            __heatLayer.IsVisible = true;
            __heatLayer.FeatureSource = _featureSource;
            map.ZoomToMarkers(_markers);
            return (map.CurrentExtent.GetWellKnownText());
Hello Jean-marie,
 Thanks for your post, but in your code, you miss some other part so I can’t debug on it.
 Then I did test depend on our HowDoISamples—>LayersFeatureSources—>LoadAHeatLayer, I modified the code to make it all define in the view. It’s working fine, can you compare this sample and yours to see any difference?
Hi Gary,
 I understand, my point is that there is a limit on how you split the code between view and controller.  In my case I have done all the overlays and  layers definition inside the view but the features load  was done from within the controller for the targeted heat layer using the map ajax call.  of course when the heat layer was loaded with features then the application was working just fine but before that the error message was on top of the map…
 thanks.
 jm
Hello Jean-marie,
 I see, sorry for the misunderstanding.
 I think for this situation, the only way is put your call in the OnLoaded event, then it will assure all the map control have registed.
