We are getting some errors when we user different values when using GetFeaturesByColumnValue
when we use : ‘OBR’ algemeen we get a exception ""ERROR: 42601: syntax error at or near “OBR”"
when we use : system.DBnull we get a exception "Conversion from type ‘DBNull’ to type ‘String’ is not valid"
We used version 7.0.0.294.
Hope you can help !
Best Regards
Jeroen
Bugs using GetFeaturesByColumnValue
Hi Jeroen,
Are you using some special layer in your code? For example: OracleFeatureLayer.
Could you please paste your code snippet here and write more detail operation process, so we can try to reproduced that local.
And how to use ‘OBR’ algemeen and system.DBnull?
