BuildIndex error
I am using MsSql2008FeatureLayer to display spatial data and I am trying to insure that I have spatial indices on all of my geometry tables.  I get an error on one table.  It has a single point type feature in it.  I have checked that the feature is valid (STIsValid).  I get this error:
Unable to cast object of type 'System.DBNull' to type 'System.Byte[]'
The Location field is not null.  I realize there is not much need for a spatial index on a table with only one record.  Is this not allowed?
Charles
This also happens with a table that contains a single line string.
Charles
Charles,
Thanks for your post.
I agree with you that this problem will be happening when calling the GetBoundingBox for an MsSqlFeatureLayer in which only one feature exists. Following code shows a way to go around this problem now; we will try to fix it in future versions.
        private void DisplayMap_Load(object sender, EventArgs e)
            string connectString = "Data Source=192.168.0.212;Initial Catalog=**;Persist Security Info=True;User ID=sa;Password=****";
            MsSql2008FeatureLayer sql2008Layer = new MsSql2008FeatureLayer(connectString, "cntry02", "ID");
            sql2008Layer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
            sql2008Layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            staticOverlay.Layers.Add("Sql2008Layer", sql2008Layer);
            sql2008Layer.Open();
            winformsMap1.CurrentExtent = GetSqlLayerBoundingBox(sql2008Layer);//sql2008Layer.GetBoundingBox();
            sql2008Layer.Close();
            winformsMap1.Refresh();
        private RectangleShape GetSqlLayerBoundingBox(MsSql2008FeatureLayer sql2008Layer)
            RectangleShape returnBoundingBox = new RectangleShape();
            try
                int count = sql2008Layer.QueryTools.GetCount();
                if (count == 1)
                    returnBoundingBox = sql2008Layer.QueryTools.GetAllFeatures(ReturningColumnsType.NoColumns)[0].GetBoundingBox();
                else
                    returnBoundingBox = sql2008Layer.GetBoundingBox();
            finally
            return returnBoundingBox;
