Cab we load shape file with out dbf file
 heloo,
i want to use my shape file  to load the map.for some shape files i dont have DBF files.for those shape files it throws an error.can we load the shape files without using dbf filles.is it possible.
Hi Raj,
 Well, you’d better generate the dbf files for those shape files, here is the code to generate the dbf file,
 GeoDbf.CreateDbfFile(“xxx.dbf”, new DbfColumn[] { new DbfColumn(“Name”, DbfColumnType.String, 10, 0) });
 Edgar
 Hi Edgar,
            if (!IsPostBack)
                ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Server.MapPath("~/Torrington Maps/majtrans2001.shp"));
                worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.Green));
                worldLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.Capital3("NAME");
                Map1.StaticOverlay.Layers.Add(worldLayer);
so where i need to  use this statement for convert in to dbf file.
GeoDbf.CreateDbfFile("xxx.dbf", new DbfColumn[] { new DbfColumn("Name", DbfColumnType.String, 10, 0) });
Hi rajanikanth,
We need to create the DBF for your shapefile before we define the Shapefile in your code. So you would want to setup the creation of your DPF perhaps like this:
            if (!IsPostBack)
             //Make the DBF file name the same as your shapefile.
 Thank tou Ryan
You’re welcome, if you have any questions please let us know.
 Edgar
