I am using the CadFeatureLayer to display cad files. First I can display Cad drawing without projection and it is working but for some reason I am getting errors time to time like :
screen cast: screencast.com/t/1AbfdBrANmk6
cad files involved attached.
jm.
CadFeatureLayer Issues / questions
Hi Jm,
Thanks for your data and video. It proved a bug and now we have fixed it in the latest version, please get the latest
version (7.0.0.148 or 7.0.148.0 might be still building) and then just
reinstall the “Map Suite Unmanaged Dependencies 7.0.124.0.msi”.
Then we can get this:
If the issue persists, please
let us know.
Hi Johnny,
My user portal seems to be stuck at 7.0.143.0 and 7.0.0.141 …
jm
Still no new version on my customer portal…
Hi jm,
There is a mistake on our daily build server and now it should be ok.
Would you please try again?
Hi Johnny,
I did install the UD package but still have an issue with the ABER-888-C-BASE drawing.
"input value out of the range parameter name: maxX undefined"
jm.
Hi Jm,
Sorry the modifications was not included in the 7.0.0.149 package but should be in 7.0.0.151. Would you please try it if the version is enable?
sorry for any inconvenience.
At the time of this writing my customer portal download is not up to date… Please check your build process.
Jm
Hi Johnny,
Was able to download daily build 7.0.151.0, updated the un-managed dependencies, but no luck still not working with my 2 files…
jm.
Hi Johnny,
I tried again this morning (updated the un-managed dependenci as well), but no luck still not working with my 2 files…
jm.
Hi Jm,
We apologize for the mistake on daily build and the long time waiting. We are upgrading the daily build system and every dll packages need to upload manually.
Currently, I test the dll package 7.0.155.0 and it can fix the issue but the package doesn’t be uploaded in customer portal. would you please wait another days for the 7.0.155.0 or higher?
Sorry again and hope you can understand.
Hi Jean-Marie,
The latest 7.0.155.0 Full Development Builds are now available in the Customer Portal.
Hi Ryan
Thanks for your support. I got the latest 7.0.155.0 Full Development Builds but I still have a CAD drawing that is not working. If you could ask Johnny to check what is not working with the ABER-888-C-BASE.zip drawing attached to this post.
thanks a lot.
jm.
Hi Jm,
We only fixed the issue from AMES-888-BASE but didn’t notice there is another issue in the ABER-888-C-BASE. Now, both of the issues are fixed in the latest unmanaged dependencies installer.
I guess you still need to wait some hours\days for the latest version 7.0.157.0. (PS, after the installation, please check the dll named “CadDumperX64” in systemroot\map suite 7.0\Cadx64or86, its modified date should be on 14th November)
Sorry for the inconvenience from daily build.
If those issues persists, please let us know and we thanks for your issues to help us to make the CAD stronger.
Regards
Hi Johnny
Still at 7/26/2013 not 11/14/2013 !!!
could you fix it soon???
thanks in advance.
jm.
Downloaded today and it is gooodddddd!!!.
thanks again!
jm.
Hi Jm,
Good to hear it works finally.
