Hi.
I got those coordenates from a GPS device, when we put the points in a google map they fit perfect, but when i load those points in the application that we are developing it has a mismatch, so i wonder if i can manipulate the projection to set the points and vehicles layers (two InMemoryFeatureLayers) where they are suposed to be, but it does reproject the whole layers isn't?
I remember that when i tried to use the google map as background there was the same mismatch the google map appears to be at southwest of the rest of the map. Any suggestion?
Can't use the code provided in the community project "snap to GPS" because there are no roads layer, the roads "appears" as the blocks are drawn.
i attach one screenshot of the app the blue line is the trail i´m getting right now and the red line is where must be drawn.
Also attach the positions file and i wish to attach the shape files for the map too, but it exceeds the max limit for attachments
GPSreadings0.txt (2.27 KB)
