Hello guys,
I can`t create the grid polygon layers, using the “Split Polygon Based On Grid” with files like “osm_ocean_polygons_simplified_1.shp”.
In the output file, I always get a result like a checkerboard.
Could you help?
input
output
Hello guys,
Could you help?
input
Thanks Alexander,
Could you attach the shape file and the code you are using. This could help use re-produce the issue.
Frank
Hello Frank,
I attached the archive. Could you check the described behavior?
Best regards,
Aleksandr
send.zip (3.9 MB)
Thanks Aleksandr,
I found the reason for this issue. The shape file you provide is 3857 projection. You need convert it to 4326 then process it. So you need add one line around line 34
ShapeFileFeatureSource.BuildIndexFile(file, BuildIndexMode.Rebuild);
ShapeFileFeatureSource shapeFile = new ShapeFileFeatureSource(file, ShapeFileReadWriteMode.ReadOnly);
shapeFile.Projection = new Proj4Projection(3857, 4326);
shapeFile.Open();
Then it works. The result will looks like
Here is the full source code.
SplitPolygons.cs (8.2 KB)
Frank
Thanks, Frank.
No problem Alexander,
Go ahead let us know if you have any more question.
Frank
