Cannot Add WindowsMap Control
 Hi there,
I just installed the Desktop Evaluate Edition 5.0, and followed the instruction exactly in the way it's written in  wiki.thinkgeo.com/wiki/Map_S...tart_Guide
It is fine up to the step, adding MapSuiteCore.dll to the reference, but then whne I try to drag and drop the WindowsMap control from Toolbox to a Form, it gives the following error.
I have no idea what to do. Would you please help me out? Thanks a lot.
Kaori
Kaori,
 From the error message, it seems the problem is caused by that could not load GeoAPI.dll, can you check if this file is in the same folder of others, it should have four dlls, MapSuiteCore.dll, DesktopEdition.dll, NetTopologicalSuite.dll and GeoAPI.dll
Thanks James,
 Actually the problem was that I was trying to add WindowsMap control into a project which .net version was 2.0. I didn’t know that the MapSuite 5.0 doesn’t go along with .net 2.0.
 Anyway it was solved, thank you for your response :)
Kaori,
 Any more question just let us know.
