I see from a previous answer that sql queries are not supported on tab files. The answer was back in February. Any idea when this will be added? Makes tab files useless for me if I cannot search and highlight a particular feature.
Sorry to tell you we haven’t find a way to access the .dat file of the tab file. The dat file has the same structure as dbf file, we tried to change the extension of dat file to dbf, it could be queried by Oledb, but when we change it back, it can not. So we’ll keep on doing the research on this and maybe one day we’ll find out the solution.
I’ll see if I can find a way round this that you can use.
OleDb causes me problems with other files. If I have lots of shape files with long filenames where the first 8 characters are the same, it can confuse OleDb which seems to use short filenames.
One possible solution is for us to create a copy of the .DAT file as a .DBF file. This depends on how the layer determines CanExecuteSqlQuery - is this based purely on the layer type or is it determined by if there is a .DBF file present? If the former can this be changed to the latter then I will be able to work round the missing search functionality.
Thank you for you suggest, creating a copy does solve the execute problem, but what time to copy that? Only two ideas come to my mind, 1), before the executing, copy the file and if there are changes, replace the original file. 2), copy the file when Opening and replace the file when closing.
But the two ways both have the performance issue if the file is big. We’ll continue working on this till we find a solution.
I'm not suggesting you should copy the file. What I'm suggesting is that you should check to see if there is a .dbf and if so allow a sql query to be run.
I have a GIS utility that my customers use to import GIS layers into our system. As part of an import I generate index files. I can also copy .dat files as .dbf files.
My main problem is that I think you turn off sql queries for .tab files. What I'm asking is for you not to do this but instead to check if there is a .dbf file.
I have found a way to access the .DAT files from a SQL query. If you perform a query like select * from parcels then the odbc driver looks for a parcels.dbf file. If you perform a query like select * from parcels.dat then you can specify the exact file to query. Tried it and it seems to work. May help you move forward.
One more question. How do you link the row in the query result set to the shape? In a shape file you can add a recid column using the ShapeFileFeatureLayer.BuildRecordIdColumn command. There does not appear to be a similar command for a TabFeatureLayer?
After further testing my suggestion above about adding the extension to the query does not work.
I still need the answer to the question: How do you link the row in the query result set to the shape in tab files? In a shape file you can add a recid column using the ShapeFileFeatureLayer.BuildRecordIdColumn command. There does not appear to be a similar command for a TabFeatureLayer?
The tab file’s structure is not the same as the shape file, e.g. the first record’s column value might not be the first record in dat file, so the records in .map file and .dat file are not one on one. The only way to get the feature from the information in table is the following code, Collection<Feature> features = new Collection<Feature>(); foreach (DataRow item in ta.Rows) { //Assume the first column is the “ID” column and it’s the primary key. string columnValue = item.ItemArray[0].ToString(); features.Add(tab.QueryTools.GetFeaturesByColumnValue(“ID”, columnValue)[0]); }
Thanks for the code. Unfortunately it does not work. The first column in the dat file is not an ID. I cannot see any column that could be an ID.
How does it work going from the shape to the database? This works OK - if I select a shape from the layer I can get all columns so there must be a link from the shape to the database. If so I should be able to follow it the other way.
I have attached the tab file set so you can examine it.
Sorry for my previous reply that I told you the structure is different from the shape file, but in fact, they are the same, that means using GetFeatureById(n) can get the nth record in the dat file, so we added a method TabFeatureSource.BuildRecordIdColumn to build the Id Column in the dat file, after that you can get the features by
foreach (DataRow item in ta.Rows) { //Assume the last column is the "ID" column and it's the primary key. string id = item.ItemArray[last].ToString(); features.Add(tab.QueryTools.GetFeatureById(id, ReturningColumnType.AllColumns); }
Have downloaded and tested version 136. Works fine on the tab file I sent but throws an ArgumentOutOfRangeException exception on one I created through map suite:
{"Index and length must refer to a location within the string.\r\nParameter name: length"}
at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at System.String.Substring(Int32 startIndex, Int32 length) at ThinkGeo.MapSuite.Core.TabFeatureSource.BuildRecordIdColumn(String tabFileName, String fieldName, BuildRecordIdMode rebuildNeeded, Int32 startNumber, Encoding encoding) at ThinkGeo.MapSuite.Core.TabFeatureLayer.BuildRecordIdColumn(String tabFileName, String fieldName, BuildRecordIdMode rebuildNeeded) at Kern.Client.Windows.Controls.UserControls.MapBase.SaveTabAsset(String userAssetPath, Feature feature, IEnumerable`1 assetFieldValues, String safeJobNumber) in c:\TFS\KernMobile_V5\Main\Kern.Client.Windows\Kern.Client.Windows.Controls\UserControls\MapBase.xaml.cs:line 2430
I have attached the tab file that causes the issue.
