Can't get point text positioing to work
I can;t get the label fro a point (e.g. town) to be positioned such that it doesn't overlap the point marker.
wrigin code such as
placesLayer.ZoomLevelSet.ZoomLevel14.DefaultTextStyle.XOffsetInPixel = 20;
doesn't appear to do anything.
What do I do?
cheers
Matt
Matthew,
 The textStyle.OffsetInPixel works fine in my test, can you let me know more about your issue, can you send me some code?
 By the way, here is how to set the offset of the markers.
 Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage.TextOffsetX = 25;
I'm obviously confused about terminology. What's a MarkerOverlay (got to do with it)?
I was trying to follow the example 'ChangePointLabelPlacement'. Is that wrong.
What I am doing:
1. Adding a ShapeFileFeatureLayer which loads a .shape file which contains towns (and other things)
ShapeFileFeatureLayer placesLayer = new ShapeFileFeatureLayer(MapPath("~/App_Data/Maps/AAGazetteer, GB_point.shp"));
2. Setting zoom levels such that different towns/cities appear at different zoom levels
Collection<Style> capital = new Collection<Style>();
capital.Add(PointStyles.Capital1);
capital.Add(new TextStyle("NAME", new GeoFont("Arial", 9), new GeoSolidBrush(GeoColor.StandardColors.Black)));
ValueStyle zoom8 = new ValueStyle();
zoom8.ColumnName = "LEVEL";
zoom8.ValueItems.Add(new ValueItem("8", capital));
placesLayer.ZoomLevelSet.ZoomLevel09.CustomStyles.Add(zoom8);
placesLayer.ZoomLevelSet.ZoomLevel09.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
placesLayer.ZoomLevelSet.ZoomLevel09.DefaultTextStyle.XOffsetInPixel = PointLabelXAxisPixelOffset; // a const int of say 25
placesLayer.ZoomLevelSet.ZoomLevel09.DefaultTextStyle.PointPlacement = PointPlacement.CenterRight;
is this right/wrong?
cheers
Matt
Matthew,
 I see. so what you want is to label all the features which has the LEVEL equals to "8", right? You cannot change its Offset by setting DefautTextStyle, because you are using CustomStyles which is not "DefaultTextStyle". You can try this code instead.
TextStyle textStyle = new TextStyle("NAME", new GeoFont("Arial", 9), new GeoSolidBrush(GeoColor.StandardColors.Black));
textStyle.XOffsetInPixel = PointLabelXAxisPixelOffset;
textStyle.PointPlacement = PointPlacement.CenterRight;
capital.Add(textStyle);
That did the trick.
 Thankyou
 Matt
You are welcome, Matt.
