Can't we delete feature using ExecuteNonQuery method in QueryTools
When I tried to delete feature its showing “The SQL Query mode is not supported.”
int result = _crudLayer.QueryTools.ExecuteNonQuery("delete * from table Name where "); //The SQL Query mode is not supported.
Can’t we delete feature using ExecuteNonQuery method rather than editing tools ? i.e.,
myFeatureLayer.EditTools.BeginTransaction();
myFeatureLayer.EditTools.Delete(myFeature.Id);
myFeatureLayer.EditTools.CommitTransaction();
Our QueryTools for shape file is supported via OLEDB, I think Delete via ExecuteNonQuery is not supported.
You can delete it just like your code shows by the Delete API.
OK, Thank you …
Thanks for your update.
