Census Tract/Block from address
Is there a way to get a census block and census tract from a given address?  In other words, if I have a known address, is there a way to get the census block information from geocoder?  Currently I am able to see CensusBlockR and CensusBlockL from the street match, but those values aren't really close to the correct block, in the trials I ran earlier, those blocks don't even border the street at all, they are about 5 blocks away.  I was hoping to see the blocks that border the street from that result set.  Is there a different result set that would better estimate which block and tract the address is in?
Using UsaGeocoder the following line produces results that I don't understand.
Collection<GeocoderMatch> result = new Collection<GeocoderMatch>();
result = myGeo.Match("714 S 8th St", "50428");
The result then contains:
CensusBlockR = 2087
CensusBlockL = 3020
That Address belongs to block 3038.
 Jake,
Thanks for your question.
Our Geocoder index is based on the TIGER data which released by US Census Bureau, and I have checked the original 2010 TIGER/Line data, it shows the same information that you got.
Please follow the steps below:
1, Download the edges and faces data which represent all lines, "714 S 8th St", "50428" is inside Cerro Gordo county, so the corresponding file is
ftp://ftp2.census.gov/geo/tiger/TIGER2010/EDGES/tl_2010_19033_edges.zip
ftp://ftp2.census.gov/geo/tiger/TIGER2010/FACES/tl_2010_19033_faces.zip
2. Open the tl_2010_19033_edges.dbf file and find the record which FULLNAME field's value is S 8th St and the house number is from 700 to 799, the TLID is 7288383,
            19
            033
            7288383
            204402263
            204402259
            S1400
            S 8th St
            4678
            799
            701
            798
            700
            50428
            50428
            S
            N
            N
            Y
            N
            N
            N
            N
            N
            N
            N
            N
            51183283
            51183280
OK, now you got the TFIDL and TFIDR, you will use them to find the block number in faces file.
3. Open the tl_2010_19033_faces.dbf file and find the record which TFID equal the above TFIDL/TFIDR number.
            204402263
            19
            033
            950700
            2
            2087
            90720
            14025
            07620
            17506
            04
            010
            019
            033004
            50428
            00200
            19
            033
            950700
            2
            2094
            90720
            14025
            07620
            04
            006
            012
            033009
            50428
            32380
            L
            N
            11576
            +43.1305685
            -093.3794512
            204402259
            19
            033
            950700
            3
            3020
            90720
            14025
            07620
            17506
            04
            010
            019
            033004
            50428
            00200
            19
            033
            950700
            3
            3038
            90720
            14025
            07620
            04
            006
            012
            033009
            50428
            32380
            L
            N
            33432
            +43.1306360
            -093.3778253
Sorry for inconvenience.
