Change Default Mouse Operation Functionality
Hiiii,
I want to change the default functionality for Mouse Operation......
->  I need to change the default functionality for zooming selected area by using key-Shift + mouse click with only mouse click event without pressing shift key.
If possible, how will I do using javascript as well as in C# code?
Badal
Hi Badal,
You could achieve that by setting the TrackZoomMaskType property of MouseMapTool. Please refer to the code snippet bellow:
Map1.MapTools.MouseMapTool.TrackZoomMaskType = TrackZoomMaskType.None;
Hi Johnny,
How could I set the TrackZoomMaskType property of MouseMapTool in javascript.
Badal
Hi Badal,
 I got this code from somewhere else on these forums, but I believe it’s what you are looking for.
 var zoomControl;
 zoomControl = map.getControlsByClass(“OpenLayers.Control.Navigation”)[0];
 zoomControl.zoomBoxKeyMask = OpenLayers.Handler.NONE;
 zoomControl.handleRightClicks = false;
 zoomControl.draw();
 Then to use it, you use the activate() or deactivate() methods. So to turn it on, you just say:
 zoomControl.activate();
 and to disable:
 zoomControl.deactivate();
 I placed this code inside the OnMapCreated method of the map. Hope this helps.
Badal,
Janet’s solution is the right one. If you want to use the Shift+.., you just need to set the zoomControl.zoomBoxKeyMask as OpenLayers.Handler.MOD_SHIFT.
Please have a try and any questions please let us know.
Janet,
Thanks for providing the solution very much, you did give us a big hand.
