I’m working on doing some InMemoryLayer thematic maps using a custom style with the ValueStyle. We’re trying to render about 70k points on the map and it can take a few seconds. We’re using the MultipleTile TyleType and can see each of the tiles drawing which is good because it indicates progress to the user.
We’re using MapSuite WPF (tried 7 & 8) in a hosted container in WinForms
Where we’re having a problem is when we try to change ValueStyle before the layer has finished refreshing (something the selected color range isn’t looking so good so you might want to pick a different one without waiting a few seconds for the refresh to complete). We almost always get this error within 2-3 attempts:
I’m probably missing something pretty fundamental here - only been using MapSuite a few weeks and had been making good progress until this
An unhandled exception of type ‘System.InvalidOperationException’ occurred in WpfDesktopEdition.dll
Additional information: Collection was modified; enumeration operation may not execute.
System.InvalidOperationException was unhandledHResult=-2146233079Message=Collection was modified; enumeration operation may not execute.Source=WpfDesktopEditionStackTrace:at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.<>c__DisplayClass6.<DrawException>b__4()at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)at System.Windows.Threading.DispatcherOperation.InvokeImpl()at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)at System.Windows.Threading.DispatcherOperation.Invoke()at System.Windows.Threading.Dispatcher.ProcessQueue()at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)at System.Windows.Threading.Dispatcher.Run()at System.Windows.Application.RunDispatcher(Object ignore)at System.Windows.Application.RunInternal(Window window)at System.Windows.Application.Run(Window window)at System.Windows.Application.Run()at WpfApplication1.Application.Main() in D:\Projects\SpatialestX\MapSuite-Playground\WpfApplication1\obj\x86\Debug\Application.g.vb:line 65at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()at System.Threading.ThreadHelper.ThreadStart_Context(Object state)at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)at System.Threading.ThreadHelper.ThreadStart()InnerException:
