Hello all
we have a project that the user want to show number of project based on province for example if New York has 120 project , we should show the map and change the "NY" to "NY(120 Project)" . we have the name of Province in layer file and number of Project in database. how do i change the value of Column in Layer file?
I can show the Province name of layer file with below code. but i wanna change it. is it possible or not?
foreach (var d in collfeatures) // get all Province in Layer file
int ID = Convert.ToInt32(d.ColumnValues[ColumnId]); // Get the ID of Province in Layer File
string ProvinceName=d.ColumnValues[ColumnName].ToString(); // Get the Name of Province in Layer file
Collection<Style> stylecoll = new Collection<Style>(); // Create Style
var data = collGraduatedMapData.Where(a => a.ID == ID).FirstOrDefault(); //get the number of Project based on Province ID
stylecoll.Add(new TextStyle(ColumnName, new GeoFont("Arial", 10, DrawingFontStyles.Regular), new GeoSolidBrush(GeoColor.StandardColors.Black)));
classBreakStyle.ClassBreaks.Add(new ClassBreak(Convert.ToDouble( ID), stylecoll)); layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(classBreakStyle);
layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(AreaStyles.Country1); layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; layer.DrawingMarginPercentage = 100; Proj4Projection proj4 = new Proj4Projection(); proj4.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326); proj4.ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString(); layer.FeatureSource.Projection = proj4; if (!proj4.IsOpen) proj4.Open(); graduatedoverlay.Layers.Add(layer);
Changing the Value of layer column
Hi Hassan,
Please try the DrawingFeatures event, in this events, we can change the column value dynamically in memory. Some codes as following:
shapeFileFeatureLayer.DrawingFeatures += BackgroundMapsController_DrawingFeatures;
void BackgroundMapsController_DrawingFeatures(object sender, DrawingFeaturesEventArgs e){foreach (Feature item in e.FeaturesToDraw){int ID = Convert.ToInt32(item.ColumnValues[ColumnId]); // Get the ID of Province in Layer Filevar data = collGraduatedMapData.Where(a => a.ID == ID).FirstOrDefault(); //get the number of Project based on Province ID
item.ColumnValues[“Name”] = item.ColumnValues[“Name”] + data;}}
Any questions, don’t hesitate to let us know.
Thank you so much it’s working very well
Great!
Don’t hesitate to let us know if any other questions.
