Chrome browser full size mode-WMS layer snot seen
Hi ThinkGeo,
When browsing ThinkGeo maps (Websamples.thinkgeo.com) in Chrome browser, the map does not  show up. (switching back and forth between smaller size to full size results in disappearance of map) see attached fig.
Initially this problem used to be only visible for Safari. Now it is seems to having for Chrome browser too... Please have a look at it as it s important for use to support our application on Chrome.
Anil
ChromeBrowserFullSize.zip (83.8 KB)
Hello Anil,
 Thank you for your post, I saw your picture, it’s weird, I have tested it in my computer( windows 7 64bit, Chrome 13.0.782.220), it’s working fine.
 Could you please download the HowDoISamples and have an other try? I want to make sure if there is some conflicts in your computer.
Hi Gary,
I tried on to 2 different machines and still run into the problem switching Full size mode (and then back and forth to reszie) or when to minimize Tree view. I am also using Win7 64 bit machines.
Anil
Anil.
 Yes, we can reproduce this in another machine now, we will compare the difference and try to find the root cause.
 Will let you know as soon as possible.
Hi Gary,
 Is there any update on this issue? Thanks
 Anil
Anil,
 We are working on this, we found it should be caused by a small missing or a wrong configuration, it’s not easy to resolve it immediately, and we will have a November release, I think we can fix this before that.
 Sorry for get you in trouble, thank you for your patience.
