I have an issue where I want to use ClassBreaks or UniqueValue styles, I define the style, create the value collection and set the the column to use, say “WidgetType”:
ValueStyle style = new ValueStyle("WidgetType", widgetItemsCollection);
I want to also print a text label of the type next to the posting.
TextStyle textStyle = new TextStyle("WidgetType", font, brush);
When this is run, I get a Pink Map with a red X and “An item with the same key has already been added” (or something like that).
If I set the valuestyle on it’s own, or just post the text, all is fine. Selecting a different column for each is fine, just when they are the same column.
Any initial thoughts, I suppose if I post them as two different layers it would work, but that seems like extra work.
Chris
