ClassBreakStyle
Hi all,
I have a MapShapeLayer on which I add some point shapes. On the Feature I set the ColumnsValues property (which is a Dictionary<string, string>), And then on the layer I set some ClassBreakStyle. The problem is that when I draw the layer an ArgumentException -  {"The class breaks you have provided are invalid."} is thrown.  Does anyone have any idea what is wrong?
//I create the fetures like this
Dictionary<string, string> columnValues = new Dictionary<string,string>(2);
                columnValues.Add("leads", reportRow["leads"].ToString());
                columnValues.Add("zip", reportRow["zip"].ToString());
                Feature feature = new Feature(new PointShape(Convert.ToDouble(reportRow["Longitude"]),
                    Convert.ToDouble(reportRow["Latitude"])), reportRow["zip"].ToString(), columnValues );
//i create the break style like this
ClassBreakStyle classBreakStyle = new ClassBreakStyle("leads");
            Color standardColor = ColorTranslator.FromHtml(flowRanges.Rows[0]["color"].ToString());
            GeoColor color = GeoColor.FromArgb(standardColor.A, standardColor.R, standardColor.G,
                standardColor.B);
            ClassBreak range = new ClassBreak(0, PointStyles.GetSimpleCircleStyle(color, 10));
            classBreakStyle.ClassBreaks.Add(range);
            aeLeadFlows.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(classBreakStyle);
            aeLeadFlows.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
I solved the problem… It seems adding as the first ClassBreak one with the value of double.MinValue is required.
Christian,
   I will report that error message to the developers.  They have been putting in a lot of effort to give good error message when things go wrong.  In this case message was not that enlightening.  I will find out more about this.  Thanks for reporting it!
