Clearing InteractiveOverlays gives problems
I'm not sure if this could be a possible bug but after clearing the InteractiveOverlays collection of a map (WPF, winforms) with map.InteractiveOverlays.Clear(); new instances of EditOverlay and TrackOverlay need to be created in order to use them for editing. After the new instances are created and after setting the trackmode of the TrackOvleray to a particular shape, nothing happens in the TrackEnded event of the TrackOverlay after drawing a shape on the map. Hence, no shape appears.
Any ideas?
Nat
Christian,
I tried the following code, and it works fine like a champs.
winformsMap1.Overlays.Add(worldMapKitDesktopOverlay);
winformsMap1.InteractiveOverlays.Clear();
TrackInteractiveOverlay trackInterativeOverlay = new TrackInteractiveOverlay();
winformsMap1.TrackOverlay = trackInterativeOverlay;
winformsMap1.InteractiveOverlays.Add(trackInterativeOverlay);
EditInteractiveOverlay editInteractiveOverlay = new EditInteractiveOverlay();
winformsMap1.EditOverlay = editInteractiveOverlay;
winformsMap1.InteractiveOverlays.Add( editInteractiveOverlay);
ExtentInteractiveOverlay extentInteractiveOverlay = new ExtentInteractiveOverlay();
winformsMap1.ExtentOverlay = extentInteractiveOverlay;
winformsMap1.InteractiveOverlays.Add(extentInteractiveOverlay);
winformsMap1.CurrentExtent = new RectangleShape(-139.2, 92.4, 120.9, -93.2);
winformsMap1.Refresh();
Hi,,
Thx! I found the problem. It seems though the Edit and Track Interactive Overlays form part of the InteractiveOverlays collection, so that when the collection is cleared, so are the Edit and Track Overlays. I don't think it was like this prior to version4. I could be mistaken. All I did was remove all interactive overlays except the Edit and Track Ovberlays.
Christian,
 Thanks for your reply.
 I only remember we did some minor changes on the GeoCollection itself, I am not sure that is the reason for this problem. While, we did not change this logic for quite a long time since then.
