I am working on the Web Edition and I show the zip codes on the map.
I can get the click event fired in the server side code(C#) and make selection/highlight on the clicked zip code.
I here attached my C# code. The code is not clean yet.
I am looking for a way to get the clicked zip code in client side javaScript.
Do you have any sample code for that? Or would you please advise me how to do it?
Thank you
shwe
protected void Page_Load(object sender, EventArgs e)
if (!IsPostBack)
Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean);
Map1.MapTools.MouseCoordinate.Enabled = true;
//Load from shape file and draw each zip code for New Jersey
ShapeFileFeatureLayer stateLayer = new ShapeFileFeatureLayer(@"C:\temp\WebSites\ThinkGeo\Data\NJ\tl_2010_34_zcta510.shp", @"C:\temp\WebSites\ThinkGeo\Data\NJ\tl_2010_34_zcta510.idx");
stateLayer.Name = "StateLayer";
stateLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Park1;
stateLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
stateLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("ZCTA5CE10", "Arial", 8, DrawingFontStyles.Italic, GeoColor.StandardColors.Black, 3, 3);
Map1.StaticOverlay.Layers.Add(stateLayer);
//This layer is for showing the selected zip code
InMemoryFeatureLayer selectLayer = new InMemoryFeatureLayer();
selectLayer.Name = "SelectLayer";
selectLayer.Open();
selectLayer.Columns.Add(new FeatureSourceColumn("ZCTA5CE10"));
selectLayer.Close();
selectLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.FromArgb(150, GeoColor.StandardColors.Red));
selectLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
LayerOverlay selectOverlay = new LayerOverlay();
selectOverlay.Name = "SelectOverlay";
selectOverlay.Layers.Add("SelectLayer", selectLayer);
selectOverlay.IsBaseOverlay = false;
Map1.CustomOverlays.Add(selectOverlay);
Map1.CurrentExtent = GetFullExtent(stateLayer);
//selects the zipcode = 08812
//DisplayZip2("08812");
//Get the position of the click, get the feature ( zip code) on the position and selects/highlights the zipcode
protected void Map1_Click(object sender, MapClickedEventArgs e)
Collection<string> columnNames = new Collection<string>();
columnNames.Add("ZCTA5CE10"); // column for zip code
LayerOverlay stateOverlay = (LayerOverlay)Map1.StaticOverlay;//stateOverlay
ShapeFileFeatureLayer stateLayer = (ShapeFileFeatureLayer)stateOverlay.Layers[0];
//find the feature ( zip code) on the clicked point
stateLayer.Open();
Collection<Feature> features = stateLayer.FeatureSource.GetFeaturesNearestTo(new PointShape(e.Position.X, e.Position.Y), Map1.MapUnit, 1,
stateLayer.Close();
//select/highlights the zipcode
LayerOverlay selectOverlay = (LayerOverlay)Map1.CustomOverlays[0];//SelectOverlay
InMemoryFeatureLayer selectLayer = (InMemoryFeatureLayer)selectOverlay.Layers["SelectLayer"];
if (features.Count > 0)
if(!selectLayer.InternalFeatures.Contains(features[0]))
selectLayer.InternalFeatures.Add(features[0]);
else
selectLayer.InternalFeatures.Remove(features[0]);
selectOverlay.Redraw();
