Would you consider creating a Click-Once deployment package for the native code dlls required by map suite 3.0? We deploy our apps using click once almost exclusivly and it was very nice just being able to xcopy dll Map Suite 2.0 dlls. I understand why you are using the open source native dlls, but it does complicate deployment, but having pre defined click-once package would make it much easier to deploy.
In order to test deployment of our project I went ahead a created a very basic click-once package. Just had to add both the x86 and x64 msm to an msi (I could have put a test in for which os was installed, but didn't bother for the test). Then I found some info on the web to create a simple deployment package. The package just has to be put in this location for VS08 and then it will show up as a click-once pre-rec.
