Compressed GeoTiff
I was trying to use some GeoTiff files using code like:
GeoTiffRasterLayer myTiffLayer = new GeoTiffRasterLayer(@"C:\Users\Public\Documents\Raster\SU01_v2.tif");
But when try to open the layer I get:
 {"Cound not open the incoming Image, please check the tiff image is valid."}
However I found that I could open the file either using GdiPlusRasterLayer or by opening the tiff file in MS-Paint and re-saving outside of MapSuite.  I am pretty sure this is because the file(s) are compressed using LZW.
1.  Is LZW compression a problem for GeoTiffs?
2.  Also if I use GdiPlusRasterLayer is there a way I can still geo-reference using the TFW file?
Jonathan
Hi Jonathan,
 Thanks for your questions!
 We do not support LZW compressed GeoTiff files.You would need to write a utility or method to uncompress these and then load them into the control.
 If you wish to use a GeoTiff with an embedded georeference information you would set GeoTiffLibraryType.UnmanagedLibTiff.
 If you have a seperate world file (.tfw) you would use the GeoTiffLibraryType.ManagedLibTiff.
Ryan,
Thank you for the information about the library type, currently we do use a separate world file.
Jonathan
Glad to be of assistance!
