I’m adding my markers to an InMemoryMarkerOverlay, and applying ValueMarkerStyles to define which icon, a red dot or green dot, will represent each marker. So far it’s working fine, but I’d like to cluster these markers in a way that if any marker in the cluster should be represented by a red dot, the cluster marker is also a red dot; otherwise it’s a green dot. This is the code I’m using to generate the markers (based on another thread I found) -
    private InMemoryMarkerOverlay getMarkers()
        //Create a InMemoryMarkerOverlay with one feature column named "ValueColumn"
        InMemoryMarkerOverlay markerOverlay = new InMemoryMarkerOverlay("Markers", new FeatureSourceColumn[] { new FeatureSourceColumn("AlertStatus") });
        //Style for 'ok' markers
        var okStyle = new PointMarkerStyle()
            WebImage = new WebImage(@"/Content/MapPins/greendot.png"),
        //Style for 'alert' markers
        var alertStyle = new PointMarkerStyle()
            WebImage = new WebImage(@"/Content/MapPins/reddot.png"),
        //Add styles to a valueMarkerStyle, assign to the styles to the respective values.
        ValueMarkerStyle valueMarkerStyle = new ValueMarkerStyle("AlertStatus");
        valueMarkerStyle.ValueItems.Add(new MarkerValueItem("Ok", okStyle));
        valueMarkerStyle.ValueItems.Add(new MarkerValueItem("Alert", alertStyle));
        //sample 'ok' marker.
        var okMarker = new PointShape(-80, 33).ConverToMeter();
        var okMarkerColumnValues = new Dictionary<string, string> { { "AlertStatus", "Ok" } };
        //sample 'alert' marker
        var alertMarker = new PointShape(-80.1, 33).ConverToMeter();
        var alertMarkerColumnValues = new Dictionary<string, string> { { "AlertStatus", "Alert" } };
        //add the featueres to the marker overlay
        markerOverlay.FeatureSource.BeginTransaction();
        markerOverlay.FeatureSource.AddFeature(okMarker, okMarkerColumnValues);
        markerOverlay.FeatureSource.AddFeature(alertMarker, alertMarkerColumnValues);
        markerOverlay.FeatureSource.CommitTransaction();
        //Set CustomMarkerStyle for markerOverlay. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
        markerOverlay.ZoomLevelSet.ZoomLevel01.CustomMarkerStyle = valueMarkerStyle;
        markerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
        //return the overlay, add it to map.customoverlays
        return markerOverlay;
In addition to that, when the user zooms into a cluster, the markers should show their respective icons (red or green dot, regardless of the cluster’s icon.
Hope it makes sense what I’m trying to accomplish. Any assistance would be appreciated.
