This is a continuation of Post 7086. I don't get any exceptions when using the <%=Map1.ClientID%>.SetDrawMode, but this causes a postback and does not change the draw mode. Please help. Thanks
Continuation of Post 7086 - draw/edit shapes with master page
David,
If you use server control to change the draw mode, it will cause a postback default. Here is a simple sample for you, you could refer to it. If you want to set more draw modes on the client side, please refer to DrawEditShapes sample in our installed samples which you can find its source code at “Samples\MapShapes\DrawEditShapes.aspx”.
Khalil
1791-WebApplication.zip (62.4 KB)
That works! This was very helpful, thank you very much!
David,
You are always so welcome.
If you still have any questions please let me know.
Khalil
