we were using 6.0.189.0 version for creating contour and it was working fine.
I upgrade to latest version to solve another problem but now I have problem with contouring, the problems are:
I'm using IsoLineLayer.GetIsoFeatures to get internal features but now all returned feature are same.
In addition you had 'heightValue' column priviously which you remove it now.
PS: recently we face many problems with thinkGeo control, it seems you change control to solve one problem and then without checking it properly you release it.
You remove MakeValid() method but some of exception asking to run it.
My publishing was working but with new version it's not working
Countour was working but not any more.(Simply check your sample Contour projects and they don't work with new libraries.)
You realesing control waiting for you clients to test, which is absolutly wrong way of releasing controls.
