MapSuite,
I’ve successfully converted the WGS84 ShapeFileFeatureLayer to SQLiteFeatureLayer that now renders properly.
What I did was to create a Projection on the ShapeFileFeatureLayer using the From & To coordinate systems below. Once the projection was assigned to the layer each feature from the ShapeFileFeatureLayer is read and then added as a new record to the SQLiteFeatureLayer.
When the SQLiteFeatureLayer is used the MapUnit is set to Meter and then it renders properly with EPSG3857.
Dennis
GEOGCS[“WGS84(DD)”, DATUM[“WGS84”, SPHEROID[“WGS84”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295], AXIS[“Geodetic longitude”, EAST], AXIS[“Geodetic latitude”, NORTH]]
To:
PROJCS["NAD_1983_StatePlane_Illinois_East_FIPS_1201_Feet",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",984250.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-88.33333333333333],PARAMETER["Scale_Factor",0.999975],PARAMETER["Latitude_Of_Origin",36.66666666666666],UNIT["Foot_US",0.3048006096012192]]
