Converting ellipseShape in prokections
Hi everybody!
Please, see the next code:
var center = new PointShape(37.540299874533, 55.8923595073993);
            var proj = new Proj4Projection
                InternalProjectionParametersString = Proj4Projection.GetEsriParametersString(4326),
                ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString()
            proj.Open();
            var elipse = new EllipseShape(center, 10, 10, proj.GetInternalGeographyUnit (), DistanceUnit.Meter);
            var elipse1 = proj.ConvertToExternalProjection(elipse);
            var dd = elipse1.GetBoundingBox ();
            var elipse3 = new EllipseShape(proj.ConvertToExternalProjection (center) as PointShape, 10, 10, proj.GetExternalGeographyUnit(), DistanceUnit.Meter);
            var dd1 = elipse3.GetBoundingBox();
And see the result on the picture in attachment. It so strange result, what do you think about it? Why dd != dd1? Thank you
Hello Alex,
 Thanks for your post, the reason is after you call  proj.ConvertToExternalProjection(elipse) the return feature is a PolygonShape not a EllipseShape, so the elipse1 is a polygon but elipse3 is a elipse.
 I think this is a problem and it will be reviewed and assigned to our development team during the next week.  Once the bug has been resolved I will post here so that you will be aware of the resolution.
