Converting WmsOverlay to WmsLayer
For my old 5.5 projects I developed a code chunk to generate a PDF output of a map window. It works by traversing the visible map layers, and drawing them to a PDF canvas when relevant, and it worked without hickups (still does).
I’m now trying to employ the same code in 9.0, but have problems getting the wms layers to display in the pdf. They work fine in the map window.
Basically what I’m doing is trying to do is create a new WmsLayer, and transferring all parameters from the map’s WmsOverlay.
Are there any caveats wrt. WmsLayer I should know when comparing versions 5.5 and 9.0 ?
Cheers
Lars
I should add, that the PDF is generated fine, and the map is included. But the map just has no wms backdrop.
Here’s a trimmed down version of the conversion taking place:
If TypeOf ovl Is WmsOverlay Then
    Dim wmsovl = DirectCast(ovl, WmsOverlay)
    Dim wmslyr = New WmsRasterLayer()
    wmslyr.Name = wmsovl.Name
    wmslyr.Uri = wmsovl.ServerUris(0)
    Try
        wmslyr.IsVisible = True
        Dim showLayers() As String = Nothing
        'traverse key/value pairs in URL, transfer to WmsLayer parameters
        If wmslyr.Uri.AbsoluteUri.Split("?").Count > 1 Then
            Dim xp = wmslyr.Uri.AbsoluteUri.Split("?").Last.Split("&")
            For Each x2 In xp
                Dim x = x2.Split("=")
                If x.Count = 2 Then
                    Select Case x(0).ToUpper
                        Case “USERNAME”
                        Case Else
                            wmslyr.Parameters.Add(x(0), x(1))
                    End Select
                End If
            Next
        End If
        'traverse key/value pairs in parameters, transfer to WmsLayer parameters
        For Each x In wmsovl.Parameters
            Select Case x.Key.ToUpper
                Case “SRS”
                    'Debug?
                Case Else
                    wmslyr.Parameters.Add(x.Key, x.Value)
                    If x.Key.ToUpper = “LAYERS” Then
                        showLayers = x.Value.Split(",")
                    End If
            End Select
        Next
        wmslyr.Open() 'fetch capabilities (needs login !)
        'set getmap parameters
        wmslyr.ActiveLayerNames.Clear() 'just in case
        For Each lyrnam In wmslyr.GetServerLayerNames()
            If showLayers.Contains(lyrnam) Then
                wmslyr.ActiveLayerNames.Add(lyrnam)
            End If
        Next
        If wmslyr.ActiveLayerNames.Count = 0 Then Throw New Exception(“Internal error: NO layers !”)
        wmslyr.OutputFormat = “IMAGE/JPEG”
        wmslyr.Crs = “EPSG:25832” 'wmsovl.GetBaseEpsgProjection.ToUpper
        'draw WmsLayer onto pdf canvas
        wmslyr.DrawingExceptionMode = DrawingExceptionMode.Default 'debug
        'wmslyr.DrawingExceptionMode = DrawingExceptionMode.DrawException
        wmslyr.Exceptions = “application/vnd.ogc.se_xml”
        'wmslyr.Exceptions = “application/vnd.ogc.se_inimage” 'default
        Try
            wmslyr.Draw(myGdiPlusGeoCanvas, LabelsInLayer)
        Catch ex As Exception
            'Debug
        End Try
        wmslyr.Close()
        'Debug.WriteLine("FAILURE :-( – Cannot draw WMS layer: " + wmslyr.Name + ": " + ex.Message)
    End Try
End If
Cheers
Lars
Hi Lars,
 I guess there isn’t any problem with the code attached here, could you provide your whole demo for us debug? You can send it to forumsupport@thinkgeo.com.
Hi Don,
Did you have a look at my project I sent ?
Cheers
Lars
Hi Lars,
 I am sorry I just found you had sent us the email with project from forumsupport mailbox, but it looks the shared link had expired.
 Could you please share us that again?
Hi Don,
I’ve sent the file again.
Cheers
Lars I.
Hi Lars,
 Thanks for your update, but I get the error as below when I tried to login:
 "Your login attempt was not successful. Please try again."
 Please have a look at that, and I am reading your code related with your convert, any update I will let you know.
