Crashing problem when there is no internet connection
 Hi I would like to show a simple image as map.
Just to test this case, I created a new wpf user control.
And on load event handler of map I'm just doing;
   wpfMap1.MapUnit = GeographyUnit.Meter;
            GdiPlusRasterLayer gdiPlusRasterLayer = new GdiPlusRasterLayer(@"D:\__nanodems__\common\BinaryData\Maps\TestMap.bmp");
            gdiPlusRasterLayer.UpperThreshold = double.MaxValue;
            gdiPlusRasterLayer.LowerThreshold = 0;
            ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay layerOverlay = new ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay();
            layerOverlay.Layers.Add(gdiPlusRasterLayer);
            gdiPlusRasterLayer.Open();
            wpfMap1.CurrentExtent = gdiPlusRasterLayer.GetBoundingBox();
            gdiPlusRasterLayer.Close();
            wpfMap1.Overlays.Add(new WorldMapKitWmsWpfOverlay { Projection = WorldMapKitProjection.SphericalMercator });
            wpfMap1.Overlays.Add(layerOverlay);
            wpfMap1.Refresh();
If computer is connected to the internet everything is fine. But if there is no internet connection, it crashed right after map is loaded with "Object reference not set to an instance of an object."
And stack trace is below;
   at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.DrawException(GeoCanvas geoCanvas, Exception exception)
   at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.Draw(GeoCanvas geoCanvas)
   at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.KxU=(Object LBU=)
   at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
   at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
   at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
Many thanks
Hello ABDULKADIR,
 Thanks for your post, I think the problem is because you use WorldMapKitWmsWpfOverlay, it will throw exception if you view the place didn’t have cache and no internet connection, to avoid it throw exception, you can set:
 DrawingExceptionMode = DrawingExceptionMode.DrawException
 I hope this can help.
