I am new to your WPF Map components. We need using your WPF Map components to do:
(1). Create new shapefiles from scratch and save the shapefiles to disk.
(2). Rebuild existing shapefiles by removing some old fields and add new fields, and changing fields’ value. Then finally save the rebuilt shapefiles to disk.
Would you tell me where I can find sample code to do these jobs?
Your sample code answered my questions. Thank you so much.
We have Windows Map applications using ESRI MapObjects since 1997. Now we are upgrading the applications to WPF on .NET platform. Actually I am evaluating your Map Suite products for this upgrading. If your Map Suite can do the same jobs as ESRI MapObjects for our applications, we will choose your products to replace ESRI MapObjects in the new applications.
So I will ask more your code samples that can do the same jobs as ESRI MapObjects in our applications.
