Create GeoImage from a resource
I have have 16x16.png files embedded in my project as resources.    I need to get one of these made into a GeoImage so that I can use it as marker in a custom DrawCore method.
I see how to get the GeoImage by reading a file or a stream.    Is there a way to get one created from an embedded resource?
 Never mind... Google to the rescue.     For anyone's reference:
    Assembly assembly = Assembly.GetExecutingAssembly();
    using (System.IO.Stream stream = assembly.GetManifestResourceStream("Pioneer.AgStudio.Extensions.Trials.Resources.AddAll.png"))
        GeoImage image = new GeoImage(stream);
        PointShape point = projection.ConvertToExternalProjection(
                    BaseShape.CreateShapeFromWellKnownData(
                                SelectedTrial.Boundary.Geometry.Centroid.AsBinary())) as PointShape;
        canvas.DrawWorldImageWithoutScaling(image, point.X, point.Y, DrawingLevel.LevelFour);
Ted:
 Glad to hear that you’ve found a solution, but you can also do as following codes:
             MemoryStream stream = new MemoryStream();
             Bitmap map = Resources.AddAll;
             map.Save(stream, ImageFormat.Png);
 Edgar
