Hi! I found a new problem!
I saved a web site after prove that it works properly as a sample for how to use google maps adding my shapefiles over it. I worked perfectly, so I saved it and never touched again. Now I found a proble with some codes I know that work so I proved the sample again and now it gives me the same problem:
There were no adequate resources for cultural reference specified or cultural reference for the neutral. Check if "ThinkGeo.MapSuite.WebEdition.Properties.ExceptionDescription.resources" has been embedded or linked properly in the assembly "WebEdition" during the compilation time or that all the required satellite assemblies can be loaded and fully signed.
What does it mean?
Thanks a lot!!
