Current Extent cahnging event of map does not cancel extent change on e.cancel
  I tried to restrict extent of map from panning using current extent changing event of map but on cancelling the event , notting happens , it still pans
Plz help me resolve this issue.
Regards
Vivek
Hi Vivek,
 Could you please show me your code?
 Edgar
I also did something similar and the e.cancel does not work.
A sample of the code in the method wpfMap1_CurrentExtentChanging:
                        private void wpfMap1_CurrentExtentChanging(object sender, CurrentExtentChangingWinformsMapEventArgs e)
  1.             {
  2.
  3.                 //While changing zoom level. Does not allow zooming out beyond the restricted extent by using the geometric
  4.
  5.                 //function IsWithin. The new extent has to be within the restricted extent or the zoomin out will be canceled.
  6.
  7.                 if (e.CurrentExtent.GetBoundingBox().Width != e.NewExtent.GetBoundingBox().Width)
  8.
  9.                 {
  10.
  11.                     if (e.NewExtent.IsWithin(restrictedExtentForZoomOut) == false)
  12.
  13.                     {
  14.
  15.                         e.Cancel = true;
  16.
  17.                     }
  18.
  19.                 }
  20.
  21.
  22.
  23.             }
Hi, Thanks  for your feedback. It’s proved to be a bug that has been fixed now. Could you go to helpdesk.thinkgeo.com to get the latest version 7.0.109.0/7.0.0.109 or higher to have a try?
 Any questions or problems please let me know.
